Engineered for precision crosscutting and fine finishing, the CMT ITK PLUS® Fine Finishing Thin Kerf Circular Saw Blade is designed to produce exceptionally clean, low tear-out cuts in solid wood, plywood, melamine, and laminate. Its thin kerf design reduces cutting resistance and material waste while placing less load on the saw, making it an excellent choice for both cordless and corded circular saws, mitre saws and table saws.
Alternate top bevel (ATB) cutting teeth with an 8° shear angle create a slicing cutting action that scores timber fibres before cutting, which results in a superior surface finish and reduced splintering on valuable timbers and decorative boards.
These fine finish circular blades are laser-cut steel featuring expansion slots for vibration and noise reduction. They are coated in CMT’s Orange Shield® PTFE coating, which reduces resin build up, protects against corrosion and limits blade drag, making these blades an ideal choice for a superior finish in demanding applications.
For details of each specific blade, see below:
114666: 273.160.56H; 160mm x bore size 20mm (+ 16mm spacer); hook angle 12°; ATB 10°
114669: 273.165.56H; 165mm x bore size 20mm (+15.88mm spacer); hook angle 12°; ATB 15°
114670: 273.216.64M; 216mm x bore size 30mm; hook angle -5°; ATB 10°
