CMT’s ITK PLUS® Non-Ferrous & Melamine Thin Kerf Circular Saw Blades feature a negative rake engineered for cutting non-ferrous metals and melamine with exceptional accuracy and a clean finish. Designed specifically for aluminium tube, box section, extrusions, brass, copper, plastics, melamine and laminated boards, the thin kerf design removes less material with each cut, producing less waste and reducing cutting resistance. This allows the blade to pass through the material more efficiently, placing less load on the saw and motor. When used with cordless tools, the reduced power demand can also help maximise battery runtime between charges.
The Triple Chip Grind (TCG) teeth with a 6° negative rake angle provide excellent control when cutting thin hollow sections, helping to prevent the material from grabbing or collapsing while producing a clean, burr-free finish.
Laser-cut high-quality steel forms the body of these metal-cutting circular saw blades, while expansion slots reduce vibration and noise for a smoother cutting experience. The Orange Shield® PTFE coating ensures the blades are resistant to residue, rust and corrosion, and prevents overheating in use. Micrograin high-density carbide teeth can withstand high stress even when cutting composite materials, guaranteeing a long cutting life. Suitable for cordless and cordless circular saws, mitre saws, radial arm and table saws, these circular saw blades from CMT will handle difficult cuts with ease.
For details of each specific blade, see below:
114677: 276.160.48H; 160mm x bore size 20mm (+ 16mm spacer); hook angle -6°
114679: 276.165.56H; 165mm x bore size 20mm (+15.88mm spacer); hook angle -6°
114680: 276.168.52H; 168mm x bore size 20mm; hook angle -6°
114681: 276.190.64M; 190mm x bore size 30mm (+ 20 and 16mm spacer); hook angle -6°
114682: 276.216.64M; 216mm x bore size 30mm; hook angle -6°
114683: 276.250.80M; 250mm x bore size 30mm; hook angle -6°
