The CMT 286.028.16M Construction Saw Blade is built for fast, reliable cutting in demanding site and workshop environments. Designed to tackle reclaimed timber, softwood, hardwood and other construction materials, its robust tooth geometry is capable of cutting through wood containing embedded nails, screws, clips and small concrete residues. With 28 premium tungsten carbide tipped teeth and an aggressive 15° hook angle, this blade delivers rapid feed rates and dependable performance in tough conditions.
Manufactured with a laser-cut steel body for enhanced stability and accuracy, the blade combines a 3.2mm kerf with a 2.2mm plate thickness for strong, precise cuts. Premium industrial-grade chromium carbide tips provide exceptional wear resistance and a long working life, while the Alternate Top Bevel (ATB) tooth geometry produces clean, efficient cuts across a wide range of construction timbers. Ideal for builders, contractors and tradespeople, this heavy-duty circular saw blade is engineered to withstand the rigours of everyday site work.
Blade Diameter 400 mm
Web Attribute Set Circular Saw Blades
EAN Barcode 8019296016314
