{"product_id":"cmt-288-120-24h1-xtreme-conical-scoring-blade","title":"CMT 288.120.24H1 Xtreme Conical Scoring Blade","description":"\u003cp\u003eThe CMT 288.120.24H1 Xtreme Conical Scoring Blade is engineered to deliver clean, chip-free cuts in laminated boards, veneered panels and other coated sheet materials. Designed specifically for use in panel saw scoring units, its conical tooth profile creates a precise pre-score that prevents tear-out on the underside of the main cut, ensuring a flawless, professional finish. Manufactured from premium steel with precision-ground carbide teeth, this 120mm scoring blade offers exceptional durability, cutting accuracy and long service life, even in demanding workshop environments.\u003c\/p\u003e\u003cp\u003eThe conical design allows fine adjustment of the scoring width to match the kerf of the main saw blade, reducing material waste and ensuring consistently clean edges. A precision tensioned steel plate minimises vibration for smooth, reliable performance, making this CMT Xtreme scoring blade an excellent choice for cabinetmakers, joiners and professionals. Ideal for cutting melamine-faced boards, laminates and veneered panels, it delivers the accuracy and finish quality required for high end furniture and cabinetry production. Diameter 120mm x Bore 20mm,  Kerf  3.4 - 4.2mm, Teeth 24.\u003c\/p\u003e\u003cp\u003ePlease note, for optimum results, the scoring blade must be precisely aligned with the main saw blade and set to the correct height and width. This fully prevents breakout without overcutting. Use in combination with a suitable main saw blade designed for panel sizing.\u003c\/p\u003e","brand":"CMT","offers":[{"title":"Default Title","offer_id":54118869795163,"sku":"114569","price":75.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114569_xl.jpg?v=1789795212","url":"https:\/\/www.axminstertools.com\/products\/cmt-288-120-24h1-xtreme-conical-scoring-blade","provider":"Axminster Tools","version":"1.0","type":"link"}
