The CMT 380 Domino Cutter for Festool DF500 is a high-quality replacement cutter designed to deliver accurate, clean and consistent mortises when used with Festool DF500 Domino joining machines. Manufactured to exacting standards, it provides reliable performance for furniture making, cabinet construction, joinery and general woodworking applications. The cutter features a high-strength steel body with premium carbide cutting edges, helping to maintain sharpness and cutting efficiency even under demanding workshop conditions.
Designed for cutting precise Domino mortises in solid timber, sheet materials and wood composites, the cutter's twin-edge spiral design promotes smooth cutting action and efficient chip removal. This helps produce clean, accurate slots while reducing heat build-up during extended use. The black PTFE coating further improves performance by reducing friction and helping prevent resin and debris from adhering to the cutter.
Ideal for furniture makers, cabinet makers, fit-out professionals and serious woodworking enthusiasts, the CMT 380 Domino Cutter helps maximise the performance of your Domino joining system and achieve consistently accurate results across a wide range of joinery tasks.
