This CMT Orange Chrome Saw Blade is designed to deliver clean, accurate cuts in solid timber and sheet materials. Ideal for both ripping and crosscutting, it features 60 precision ground industrial chromium micrograin carbide teeth with an Alternate Top Bevel (ATB) tooth geometry for an exceptional surface finish across a wide range of woodworking applications. A 15° hook angle ensures efficient feed rates, making this blade suitable for use with table saws, mitre saws and radial arm saws in demanding professional workshops.
Engineered for smooth, reliable performance, the blade combines a 3.5mm kerf with a 2.5mm plate thickness for strength and precision. The Orange Chrome® low-friction coating helps reduce heat, resin build-up and corrosion, extending blade life, while laser cut expansion slots with sound dampening technology minimise vibration and noise during use. A precision balanced blade body with a tensioning ring further enhances stability and cutting accuracy, delivering the consistent, high quality results expected by professional cabinetmakers, joiners and furniture makers.
