The Co-Matic AF06 Light Duty Bandsaw Feeder 230V is a highly efficient feeder, ideal for light to medium use with a bandsaw. Designed for bandsaws with a size range of 500mm to 600mm, this feeder is compatible with models such as the Axminster Professional AP3600B. Thanks to its adjustable arm design, it will fit a substantial range of bandsaws.
It features a powerful 90W motor and offers a variable speed range of 1.5-12 meters per minute, making it versatile for various cutting tasks and respective timber feeding requirements. The feeder is equipped with a two-roller system, with each polyurethane-coated roller measuring 200 x 25mm, ensuring a smooth and consistent feed.
This bandsaw feeder is particularly useful for resawing larger quantities of timber, and the spring loaded design provides a smooth, accurate cut. Its variable speed control allows users to adjust the feed rate according to the material and cutting requirements, making it ideal for smaller bandsaws.
Web Attribute Set Bandsaw Accessories
EAN Barcode 5052511136483
