A medium weight power feed unit with three PU rollers, all spring-loaded to provide a constant feed rate for many machining or cutting tasks. There is a choice of four feed speeds, easily selectable by removing the side plate and re-positioning the drive gears. Reverse feed is available via a selection switch. The horizontal and vertical position of the drive head can be precisely adjusted with the aid of the two adjusting screws and then securely locked in place with the two handles. An additional feature is the ability to rotate the head through 90
Co-Matic
Co-Matic AF32 Power Feed
| Feed Speed | 5 m/min, 8 m/min, 9 m/min or 11 m/min |
| Motor Power | 240 W |
| Web Attribute Set | Power Feed Units |
| EAN Barcode | 5052511013210 |
