A lightweight power feed suitable for use on a small spindle moulder, router table or surface planer. Fitted with variable speed of 2-12m/min + reverse. The three non marking PU rollers are fitted with suspension movement for extra grip and to cope with surface irregularities. The arm is a patented 3D adjustable design for ease of use. The unit can be mounted directly onto the machine or fitted using the Co-Matic mounting base which simply clamps to the machine.
Co-Matic
Co-Matic M3 Baby Power Feed
| Feed Speed | 2 m/min to 12 m/min (var) |
| Motor Power | 90 W |
| Web Attribute Set | Power Feed Units |
| EAN Barcode | 5052511006861 |
