The 11 piece CorePlus Diamond Dry Core Drill Bit Set delivers a smooth drilling experience, ensuring precise and effortless drilling. This set is perfect for professionals and DIY enthusiasts who need reliable and efficient drilling solutions. Its 8mm diamond segments feature a high concentration of premium-grade diamond in the bond, utilising leading-edge diamond/metal bonding metallurgy for long-lasting core life.
The ribbed core body and V-groove segments enable the fast clearing of debris, allowing for a continuous fast cutting action. Additionally, the aerated core design enhances cooling and extends core life. The drill bit is 1/2 BSP threaded, making it compatible with standard core drilling machines and accessories. This 11-piece set is supplied in a sturdy aluminium storage case, keeping the set organised and protected.
For smaller sizes, such as 22mm and 28mm, the drill bit features a 10mm Hex Shank and does not require an arbor accessory.
Contains:
5 x Diamond Dry Core Drill Bits: 38mm, 52mm, 65mm, 117mm, and 127mm
6 x Accessories
Web Attribute Set Miscellaneous Boring Bits
EAN Barcode 5028485215462
