The CorePlus Diamond Dry Core Drill Bits deliver a smooth drilling experience, ensuring precise and effortless drilling. Its 8mm diamond segments feature a high concentration of premium-grade diamond in the bond, utilising leading-edge diamond/metal bonding metallurgy for long-lasting core life. Available in various sizes, this drill bit is perfect for professionals and DIY enthusiasts who need reliable and efficient drilling solutions.
The ribbed core body and V-groove segments enable the fast clearing of debris, allowing for a continuous fast cutting action. Additionally, the aerated core design enhances cooling and extends core life. The drill bit is 1/2 BSP threaded, making it compatible with standard core drilling machines and accessories.
For smaller sizes, such as 22mm and 28mm, the drill bit features a 10mm Hex Shank and does not require an arbor accessory. This versatility makes the CorePlus Diamond Dry Core Drill Bit an essential tool for all your drilling needs.
Available Sizes:
38mm, 52mm, 65mm, 117mm and 127mm.
10mm Hex Shank for Smaller Sizes: 22mm and 28mm sizes have a 10mm Hex Shank and do not require an arbor accessory.
Drill Bit Diameter 127 mm
EAN Barcode 5028485215349
