The CorePlus Diamond Tile Drill Bit 8mm is a top-tier tool designed for professionals and DIY enthusiasts alike. This drill bit is engineered to deliver fast, clean cuts on both porcelain and ceramic tiles, making it an essential addition to your toolkit.
It features leading-edge vacuum brazing technology, which ensures the diamonds stay bonded for an extremely long life. The premium-grade, braze-bonded diamonds are designed to cut through the hardest materials effortlessly.
This drill bit simplifies the drilling process, allowing you to start drilling without additional guides. It operates efficiently with minimal water cooling, eliminating the need for a continuous water feed. Additionally, it allows for continuous hole cutting by automatically ejecting core waste material. The Tri-Flat shank ensures excellent performance on cordless drills, providing stability and precision. With these features, the CorePlus Diamond Tile Drill Bit 8mm stands out as a reliable and efficient tool for all your tile drilling needs.
Web Attribute Set Miscellaneous Boring Bits
EAN Barcode 5028485215684
