The 4 piece CorePlus Diamond Tile Drill Bit Set provides professional, fast, clean cutting on porcelain and ceramic tiles. This set is perfect for achieving fast, clean cuts on porcelain and ceramic tiles, making it an essential addition to your toolkit. It features leading-edge vacuum brazing technology, ensuring the diamonds stay bonded for an extremely long life. The set uses premium-grade, braze-bonded diamonds designed to cut the hardest materials.
This drill bit set offers an easy start with no-drill guide required and operates efficiently with minimal water cooling, eliminating the need for a continuous water feed. The core waste material auto-ejects, allowing for continuous hole cutting. Additionally, the bits are fitted with a Tri-Flat shank for excellent performance on cordless drills.
The CorePlus DTDM4PC Diamond Tile Drill Bit 4 Piece Set is supplied in a handy storage case and contains the following sizes: 5mm, 6mm, 8mm, and 10mm.
