Crown
Crown Carbide Pro Replacement Round Cutter
SKU: 106066
£18.38
£15.32 Excl. VAT
  • Replacement solid tungsten carbide tip
  • For the Carbide Pro Hollowing Tool
  • 15mm circular cutter
  • Ultra long lasting cutting edges
  • Simply turn to fresh edge when dull
  • Made in USA
This is a replacement tip for a circular cutter for the Crown Carbide Pro Hollowing Tip Turning Tool. It is 15mm in diameter. Manufactured from the finest quality tungsten carbide in the USA; the tips are made from the finest Nano Particle Carbide that is hardened to an unbelievable 93 HRC. This makes them ultra long lasting and, when the edge eventually dulls, all you need do is turn the cutter to a fresh sharp cutting edge.
Made in Britain Yes
