These cryogenically treated double-ended bowl gouges can save you time and money. Why waste half a blade by seating one end permanently in a tool handle? The double-ended gouge comes with a fingernail grind on one end and a straight grind on the other. You could easily re-grind one or both edge profiles to suit your particular style or needs. Overall, the blades are approximately 480mm (19
The cryogenic technique involves subjecting the blade to a complex immersion procedure at minus 195
We offer a collet handle to take the double-ended gouges. The collet handle system gives a rock solid grip on the blade and allows you to adjust the length of the blade protrusion. You also have the potential to use other blades in the same handle.
N.B. If using the 3/8'' gouge and Axminster Woodturning Short Handle, you will need the ER20 Collet 10mm-9mm (code: 910212).
Size options : 1/2" Shank with 3/8" flute or 3/8" shank with 1/4" flute.
