These shallow flute detail gouges are great for cutting coves and beads. Vibration is minimised by having more metal as support under the cutting edge. A fine fingernail-shaped grind gives very easy entry to the start of the cut. Fitted with a 317mm (12.1/2
Crown
Crown Detail Gouge - 9.5mm(3/8")
| Made in Britain | Yes |
| Size | 2026-08-03 00:00:00 +0100 |
| Gouge Type | Detail Gouge Web Attribute Set: Woodturning Tools - Individual |
| EAN Barcode | 5052511089659 |
