The DeWALT DCF870N XR Hydraulic Impact Driver is engineered for powerful, efficient performance. Its brushless motor delivers exceptional output, extends the tool’s lifespan, and enables a more compact, lightweight design. The hydraulic mechanism ensures fast application speeds while significantly reducing impact noise for a quieter working experience.
Compact it has a 100mm body length for getting into very tight spaces, delivers 52Nm of torque and the bit is held in place with a drop and load bit holder for single handed operation.
For improved versatility, the driver includes a 3‑mode control switch, allowing you to tailor performance to the task. The 9‑LED halo light produces 82 lumens of bright, even illumination and features a dedicated flashlight mode that provides up to 20 minutes of continuous light.
Supplied as body only (no battery or charger).
Part of the DeWALT 18v Li-ion XR battery family taking standard XR and Powerstack Batteries.
Specifications
No Load Speed: 0–1,100 / 0–3,000 rpm
Impact Rate: 0–4,200 bpm
Weight: 1.32 kg
Battery Type Li-ion
Corded or Cordless Cordless
Web Attribute Set Cordless Impact Drivers
EAN Barcode 5035048833667
