DeWalt
DeWALT DCMHT562N Hedge Trimmer 250mm 18V (Body Only)
SKU: 113482
£137.98
£114.98 Excl. VAT
  • 550m blade for fast and easy hedge trimming
  • 19mm blade gap capacity
  • Up to 75 minutes of runtime per charge (with 5.0Ah)
  • Lightweight design at only 3.2kg (without battery)
  • Ergonomic over moulded hand grips for reduced fatigue
  • D-Ring handle design for complete control in different hand positions
  • Wall-mounting hook for easy storage
  • Supplied as body only
  • Part of the DeWALT 18V XR battery system family
  • Compatible with over 250 other DeWALT 18V tools
Tthe DeWALT DCMHT562N Hedge Trimmer 250mm 18V (Body Only) is a powerful and efficient tool designed to make hedge trimming tasks quick and easy. This hedge trimmer features a 550mm blade with a 19mm blade gap, allowing you to trim hedges swiftly and effortlessly. With up to 75 minutes of runtime per charge (using a DEWALT 5.0Ah battery, measured with no load), you can complete your trimming tasks from start to finish without needing to recharge.
The DeWALT DCMHT562N Hedge Trimmer is designed for comfort and ease of use. Weighing only 3.2kg (bare), it features ergonomic overmoulded hand grips that allow you to maneuver the trimmer easily and reduce fatigue during extended use. The slim profile design, which is 39% narrower than the DeWALT DCM563 18V Hedge Trimmer, makes it easier to handle and control.
The D-Ring handle design provides complete control, allowing you to activate the trimmer in different hand positions. For added convenience, the hedge trimmer includes a wall-mounting hook on the underside, making it easy to store when not in use. Additionally, it is compatible with the DeWALT hedge clippings sweeper attachment, which helps you clear away trimmings as you cut the hedge (sweeper attachment sold separately).
This hedge trimmer offers the power of corded tools with the freedom of cordless operation.
Supplied as body only without batteries and charger. Part of the 18V XR battery system, ensuring compatibility with over 250 other 18V tools.
3-year manufactures guarantee applies, subject to registration.
Battery Voltage 18 V
Battery Type Li-ion
Web Attribute Set Cordless Hedgecutters
EAN Barcode 5035048838600
