{"product_id":"dewalt-dcs391n-xr-circular-saw-165mm-18v-body-only","title":"DeWALT DCS391N XR Circular Saw 165mm 18V (Body Only)","description":"\u003cp\u003eThe DeWALT DCS391 Premium Circular Saw delivers powerful performance and exceptional control, thanks to its intelligent trigger design that ensures precision across all applications. Its high‑efficiency PM58 fan‑cooled motor, equipped with replaceable brushes, produces up to 3,700 RPM for fast, smooth cutting. A built‑in spindle lock allows quick and easy blade changes. Tool free fast depth and bevel setting; 55mm at 90 degrees and 42mm at 45 degrees, while the adjustable bevel feature offers angles up to 50° for greater flexibility.\u003c\/p\u003e\u003cp\u003eEngineered for durability, the saw features a cast magnesium base that supports repetitive, accurate cuts. The ergonomic handle with rubber overmold provides excellent comfort during extended use. This cordless circular saw is an ideal solution for trimming wood panels, chipboard, and other sheet materials.\u003c\/p\u003e\u003cp\u003eSupplied with a 165mm x 24 tooth 16mm bore TCT carbide blade, rip fence, dust extraction port and hex key as standard.\u003c\/p\u003e\u003cp\u003eSupplied as body only (no battery or charger).\u003c\/p\u003e\u003cp\u003ePart of the DeWALT 18V Li-ion XR battery family taking standard XR and Powerstack Batteries.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e No‑Load Speed: 5,150 rpm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Max Cutting Depth @ 90° = 55 mm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Max Cutting Depth @ 45° = 42 mm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Blade Size: 165 mm diameter, 20 mm bore\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Weight: 3.8 kg\u003c\/p\u003e","brand":"DeWalt","offers":[{"title":"Default Title","offer_id":54118851281243,"sku":"114264","price":124.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114264_xl.jpg?v=1789793840","url":"https:\/\/www.axminstertools.com\/products\/dewalt-dcs391n-xr-circular-saw-165mm-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
