DeWALT XR FLEXVOLT is a range of 54V cordless power tools offering unrivaled run time and performance. For the first time, professional trades can reliably undertake heavy-duty construction applications without the need for mains power.
The DCS520 XR FLEXVOLT is the first plunge saw featuring a brushless 54V motor. It is one of the most powerful cordless plunge saws available, offering the same power as an equivalent mains tool. The DCS520 is extremely accurate; supplied with a 42-tooth blade, it gives you a clean finish with minimal breakout even in laminates. The parallel plunge action results in a smooth and constant cut as the saw enters the workpiece. Variable speed allows you to select the correct speed for different types of materials, at the same time full wave electronics maintain a consistent speed under load. The 55mm depth of cut allows trimming and sizing of most common doors.
The DCS520 plunge saw is quick and easy to adjust and features a bevel cut up to 47
Supplied with 42-tooth precision saw blade, T-STAK case, 2 x XR FlexVolt 54V batteries and DCB118 charger.
Please note: the XR FLEXVOLT battery is completely compatible with all existing DeWALT XR 18V products. It offers you an unprecedented 6.0Ah of power in any XR 18V cordless tool.
