DeWALT XR FLEXVOLT is a range of 54V cordless power tools offering unrivalled run time and performance. For the first time, professional trades can reliably undertake heavy-duty construction applications without the need for mains power.
The DCS7485T2 XR FLEXVOLT table saw provides you with all the performance of a mains powered saw in a highly portable, cordless power tool. The 54V FLEXVOLT battery gives you all the benefits of a mains powered saw with the freedom of a cordless tool. You can now complete the toughest jobs without trailing cables. The DeWALT DCS57485T2 XR FLEXVOLT table saw is an excellent choice for a professional working on a construction site. The DCS57485T2 comes fitted with a 210mm 24-tooth TCT blade giving you up to 65mm depth of cut. This robust cordless table saw can crosscut, bevel and rip up to 610mm wide (enough to cut an 8 x 4 sheet in half). The rip fence features rack and pinion adjustment, front and rear locks and clear scales for maximum accuracy. The quick bevel lock features a large clear scale for easy and accurate setting of bevel cuts up to 48
Supplied with 2 x 54V XR FLEXVOLT batteries, fast charger, 24 tooth TCT saw blade, mitre fence, 2 x blade spanners, rip fence, dust port reducer and push stick.
Note: The XR FLEXVOLT battery is completely compatible with all existing DeWALT XR 18V products. It offers you an unprecedented 6.0Ah of power in any XR 18V cordless tool.
