{"product_id":"dewalt-dcs777t2-xr-flexvolt-mitre-saw-2-x-54v-batteries","title":"DeWALT DCS777T2 XR FLEXVOLT Mitre Saw 2 x 54V Batteries","description":"\u003cp\u003eDeWALT XR FLEXVOLT is a range of 54V cordless power tools offering unrivalled run time and performance.  For the first time, professional trades can reliably undertake heavy-duty construction applications without the need for mains power.\u003c\/p\u003e\u003cp\u003eThe DCS777T2 XR FLEXVOLT mitre saw provides you with all the performance of a mains powered saw in a highly portable, cordless power tool. The base is the chassis of the successful DWS777 mains mitre saw. This 54V FLEXVOLT cordless version gives you all the benefits of a mains powered saw with the freedom of a cordless tool. You will never need to lug cables, extension leads or other mains related stuff around on or off site again.\u003c\/p\u003e\u003cp\u003eThe brushless motor gives you a long and maintenance free service life. The well machined base and fence ensure consistent accuracy. The base has integrated positive stops at 15, 22.5, 30 and 45 with a maximum mitre capability of 50\u003cspecial id=\"8\"\u003e\u003c\/special\u003e both left and right. The sliding left hand fence has a measuring scale for improved material support and management.  The head runs on twin rails ensuring rigidity. The rails run internally giving a large cutting capacity, at the same time making a very compact unit for easy transportation. You can lock the head to restrict the traverse movement when repeat cutting smaller work.\u003c\/p\u003e\u003cp\u003eA built-in LED work light illuminates the workpiece for improved sighting even in bright conditions. DeWALT XPS Shadow Line cut technology provides a clear-cut indicator for fast and accurate blade alignment. The dust extraction port is DeWALT Airlock compatible.\u003c\/p\u003e\u003cp\u003eThe DCS777T2 comes fitted with a 216mm TCT blade giving you a cross cutting capacity of 270mm x 62mm, supplied with 2 x 54V batteries and charger.\u003c\/p\u003e\u003cp\u003eThe XR FLEXVOLT battery is completely compatible with all existing DeWALT XR 18V products. It offers you an unprecedented 6.0Ah of power in any XR 18V cordless tool.\u003c\/p\u003e","brand":"DeWalt","offers":[{"title":"Default Title","offer_id":54118197789019,"sku":"103058","price":729.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103058_xl.jpg?v=1789772315","url":"https:\/\/www.axminstertools.com\/products\/dewalt-dcs777t2-xr-flexvolt-mitre-saw-2-x-54v-batteries","provider":"Axminster Tools","version":"1.0","type":"link"}
