DeWalt
DeWALT DCS777T2 XR FLEXVOLT Mitre Saw 2 x 54V Batteries
SKU: 103058
£729.98
£608.32 Excl. VAT
  • Long life, maintenance free brushless motor
  • Integrated positive mitre stops (left and right)
  • Twin internal rails, large cutting capacity, compact for transport
  • Up to 48 bevel cuts
  • Machined base and fence guarantees consistent accuracy
  • XPS Shadow Line cut system for accurate, repeatable alignment
  • LED light improves sighting even on bright days
  • Dust extraction port, DeWALT Airlock compatible
  • Supplied with 2 x 54V batteries and charger
DeWALT XR FLEXVOLT is a range of 54V cordless power tools offering unrivalled run time and performance. For the first time, professional trades can reliably undertake heavy-duty construction applications without the need for mains power.
The DCS777T2 XR FLEXVOLT mitre saw provides you with all the performance of a mains powered saw in a highly portable, cordless power tool. The base is the chassis of the successful DWS777 mains mitre saw. This 54V FLEXVOLT cordless version gives you all the benefits of a mains powered saw with the freedom of a cordless tool. You will never need to lug cables, extension leads or other mains related stuff around on or off site again.
The brushless motor gives you a long and maintenance free service life. The well machined base and fence ensure consistent accuracy. The base has integrated positive stops at 15, 22.5, 30 and 45 with a maximum mitre capability of 50 both left and right. The sliding left hand fence has a measuring scale for improved material support and management. The head runs on twin rails ensuring rigidity. The rails run internally giving a large cutting capacity, at the same time making a very compact unit for easy transportation. You can lock the head to restrict the traverse movement when repeat cutting smaller work.
A built-in LED work light illuminates the workpiece for improved sighting even in bright conditions. DeWALT XPS Shadow Line cut technology provides a clear-cut indicator for fast and accurate blade alignment. The dust extraction port is DeWALT Airlock compatible.
The DCS777T2 comes fitted with a 216mm TCT blade giving you a cross cutting capacity of 270mm x 62mm, supplied with 2 x 54V batteries and charger.
The XR FLEXVOLT battery is completely compatible with all existing DeWALT XR 18V products. It offers you an unprecedented 6.0Ah of power in any XR 18V cordless tool.
Battery Capacity 6.0 Ah
Battery Voltage 54 V & 18 V
Bevel Angle Range 0 - 48
Mitre Angle Range 50 - 0 - 50
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 216 mm
Sound Power Level LwA [Uncertainty K] 104 dB(A) [3.9 dB]
Batteries Included 2
Battery Type Li-ion
Blade RPM 6,300 rpm
Sound Pressure Level LpA [Uncertainty K] 93 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 2.1 m/s² [1.5 m/s²]
Web Attribute Set Mitre Saws Cordless Globale Group: low-margin-eu
EAN Barcode 5054905003050
