This L-class vacuum will run off either batteries or mains power. It is compatible with DeWALT’s XR Li-Ion 14.4V, 18V and 54V battery packs. If no batteries are available then simply plug it into the nearest mains socket. All this makes the DeWALT DCV584L a versatile vacuum, whether in the workshop or out on site. It can cope with wet or dry applications and has a HEPA filter, which traps 99.97% of dust as fine as 0.3 microns.
The hose will connect directly to other DeWALT power tools with the Airlock feature. There is on-board tool storage for holding the additional nozzles and power cord, keeping everything tidy and to hand. A handy blower function helps quickly clear your working area.
Supplied with HEPA filter, crevice tool, wide nozzle and 2m hose.
Please note, this is a body only tool sold without batteries or charger.
Battery Voltage 54 V 18 V 14.4 V
Overall L x W x H 430 mm x 305 mm x 330 mm
Power 300 W
Rating
Sound Power Level LwA [Uncertainty K] 87 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Corded or Cordless
Max Capacity Dry 7.5 litre
Airflow Volume 955 litre/min
Sound Pressure Level LpA [Uncertainty K] 76 dB(A) [3.0 dB]
Web Attribute Set Cordless Vacuum Cleaners
EAN Barcode 5035048648865
