The cordless DCW220NT belt sander is part of the DeWALT 18V system. Thanks to the brushless motor, it offers efficiency and durability. The 75mm wide belt is suitable for a range of sanding applications, such as table tops and other larger flat surfaces. It can also be used across the grain to help flatten slightly uneven boards, whilst removing waste quickly and easily.
Fitted with variable speed, the five pre-sets make it easy to change the speed, depending on the belt grit and sanding task. Compact in size with a soft grip for comfortable handling. The machine is supplied with a dust bag, but can also be used fitted to a vacuum extractor with the supplied adaptor (34mm internal, 42mm external).
Supplied with: Dust bag, extraction adaptor, sanding belt (75mm x 533mm), T-Stak storage case.
This is a body-only machine, supplied without batteries or charger but is part of the Dewalt 18V system.
Belt Speed 198 to 320 m/min
Dust Collection Dust Bag Supplied
Sound Power Level LwA [Uncertainty K] 90 dB(A)
Corded or Cordless Cordless
Abrasive Belt Size 75 mm x 533 mm
Sound Pressure Level LpA [Uncertainty K] 82.2 dB(A)
Vibration Sanding [Uncertainty K] 3.5 m/s² [1.5 m/s²]
Plug Fitted None
Web Attribute Set Belt Sanders
EAN Barcode 5035048793848
