The DCW604NT router offers complete cordless freedom with the power and performance you would expect from a mains powered equivalent. In addition, it comes with 2 bases. The fixed gives precise height adjustment making it a very practical tool for trimming. The plunge base gives all the benefits of a standard 1/4 plunge router without tethering it to a mains socket. In its class, the DCW604NT offers unrivalled versatility.
The brushless motor provides extended battery runtimes and delivers plenty of power. A clear polycarbonate sub-base and twin LEDs greatly improve visibility. Variable speed control (16,000-27,000rpm) lets you match the speed to the cutter diameter and the material. On the fixed base, the depth ring and clamping mechanism ensure spot-on accuracy when setting the cutting depth. The plunge base features a 5-step turret for incremental cuts. Both bases have comfort grips, minimising vibration and maximising control.
The router motor unit comes with plunge base, fixed base, dust extraction shroud for fixed base, dust extraction shroud for plunge base, side fence with guide rods (plunge base), basic side fence (fixed base), 8mm & 1/4 collets, 17mm spanner, centring cone, 17mm guide bush all in a T-Stak storage case.
This is a body only machine, supplied without batteries or charger.
Battery Voltage 18 V
Collets Supplied 1/4 and 8 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Sound Power Level LwA [Uncertainty K] 89 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 78 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 2.4 m/s² [1.5 m/s²]
Cutter Speed 16,000 - 25,500 rpm
Web Attribute Set Routers
EAN Barcode 5035048713099
