DeWalt
DeWALT DCW682NT Cordless Biscuit Jointer with TSTAK 18V (Body Only)
SKU: 108782
£298.98
£249.15 Excl. VAT
  • Dual rack and pinion for accurate vertical fence adjustment
  • Easy, tool free angle adjustment.
  • Quick setting for 0, 10 and 20 biscuits plus max setting for grooves
  • Retractable anti-slip pins
  • Ergonomic handle and paddle switch for secure grip
  • Dust outlet Dewalt Airlock compatible
  • Dust bag and TSTAK case supplied
DeWALT DCW682NT-XJ is an 18V cordless biscuit jointer powered by a maintenance-free brushless motor. The brushless motor provides better battery performance and longer run times on the same batteries compared to motors with carbon brushes. The DCW682NT features tool-free adjustment. The cutting depth selection knob offers quick settings for 0, 10 and 20 biscuits. The fence adjusts from 0 to 90 and has rack and pinion vertical height adjustment and features retractable anti-slip pins to enable grooving. The angled dust port comes with a dust bag and has the DeWalt Airlock fitting for secure connection to a vacuum dust extractor. The motor has an electric brake. The paddle switch makes for easy operation.
Supplied with TCT blade, dust bag and tools in a TSTAK Storage Case.
This is a Body Only tool supplied without a battery or charger and is part of the DeWALT 18V family..
Battery Voltage 18 V
Dust Collection Dust Bag Supplied
Rating Trade/Professional
Blade Diameter 102 mm
Sound Power Level LwA [Uncertainty K] 95 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 84 dB(A) [3.0 dB]
Cutter Speed 9,000 rpm
Web Attribute Set Cordless Biscuit Jointers
EAN Barcode 5035048752920
