The DEWE315B is a powerful multitool brought to you from DeWALT for a reliable, robust and affordable tool, that completes your toolkit.
Multi-tools live up to their name as one of the most versatile tools available, it’s suitable for many applications such as plunge cuts, flush sawing, sanding, scraping, rasping and grout removal, and has the added ability to work in multiple materials with a simple and quick accessory change, with no hex key required.
The DeWALT DEWE315B multitool has a powerful motor with a variable speed trigger for oscillations of up to 22,000/min. As well as superior ergonomics and a soft comfort grip on the body to help reduce fatigue for total control all round.
Supplied with a 28 piece accessory kit containing, 1 x rigid scraper, 1 x sanding platen, 25 x sanding sheets (assorted grades), universal adaptor, 2 x hex keys: 3mm and 5mm and a tool bag.
Rating Home Workshop
Sound Power Level LwA [Uncertainty K] 97 dB(A)
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 86 dB(A)
Motor Power 300 W
Plug Fitted UK 3 pin plug
Manufacturer Part Number DEWDWE315B
Web Attribute Set Oscillating Multi-Tools
EAN Barcode 5035048447475
