{"product_id":"dewalt-dws780-305mm-mitre-saw","title":"DeWALT DWS780 305mm Mitre Saw","description":"\u003cp\u003eThe 305mm diameter blade gives you outstanding cutting performance. The DWS780 offers effortless accuracy from cutting small profiles to large section timbers up to 110 x 303mm. This is a heavy-duty machine, built for durability and fully adjustable to maintain accuracy over the life of the tool. Easy-to-use mitre and bevel controls make the tool fast and simple to change from one set-up to another. A quick release bevel stop helps set accurate bevel angles up to 49\u003cspecial id=\"8\"\u003e\u003c\/special\u003e left and right. A cam action mitre lock function makes mitre setting fast and easy for angles between 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e - 50\u003cspecial id=\"8\"\u003e\u003c\/special\u003e left and 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e - 60\u003cspecial id=\"8\"\u003e\u003c\/special\u003e right. The grooving stop allows you to cut grooves or rebates. The XPS shadow line cut indicator gives you a unique and accurate way to align the blade, at the same time illuminating the work. The large dual sliding fence gives plenty of support for tall workpieces at any angle. The electronic speed control lets you adjust cutting speed when cutting materials other than wood. \u003cspecial id=\"22\"\u003e\u003c\/special\u003eSupplied with 60 tooth TCT blade, blade spanner, dust bag and material clamp.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"DeWalt","offers":[{"title":"230 V","offer_id":54117989122395,"sku":"508664","price":679.98,"currency_code":"GBP","in_stock":true},{"title":"110 V","offer_id":54117989155163,"sku":"508665","price":679.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/508664_xl.jpg?v=1790102362","url":"https:\/\/www.axminstertools.com\/products\/dewalt-dws780-305mm-mitre-saw","provider":"Axminster Tools","version":"1.0","type":"link"}
