The 305mm diameter blade gives you outstanding cutting performance. The DWS780 offers effortless accuracy from cutting small profiles to large section timbers up to 110 x 303mm. This is a heavy-duty machine, built for durability and fully adjustable to maintain accuracy over the life of the tool. Easy-to-use mitre and bevel controls make the tool fast and simple to change from one set-up to another. A quick release bevel stop helps set accurate bevel angles up to 49 left and right. A cam action mitre lock function makes mitre setting fast and easy for angles between 0 - 50 left and 0 - 60 right. The grooving stop allows you to cut grooves or rebates. The XPS shadow line cut indicator gives you a unique and accurate way to align the blade, at the same time illuminating the work. The large dual sliding fence gives plenty of support for tall workpieces at any angle. The electronic speed control lets you adjust cutting speed when cutting materials other than wood. Supplied with 60 tooth TCT blade, blade spanner, dust bag and material clamp.
Bevel Angle Range 49 - 0 - 49
Dust Collection Dust Bag Supplied
Mitre Angle Range 50 - 0 - 60
Overall L x W x H 770 mm x 470 mm x 396 mm
Rating Trade/Professional
Blade Diameter 305 mm
Sound Power Level LwA [Uncertainty K] 100 dB(A) [3.0 dB]
Blade RPM 1,900 - 3,800 rpm
Sound Pressure Level LpA [Uncertainty K] 88 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] <2.5 m/s² [1.5 m/s²]
Voltage 230 V
Web Attribute Set Mitre Saws Mains Powered Globale Group: low-margin-eu
EAN Barcode 5035048332320
