{"product_id":"dewalt-extreme-runtime-saw-blade-305mm-x-2-16mm-x-30mm-78t","title":"DeWALT Extreme Runtime Saw Blade - 305mm x 2.16mm x 30mm 78T","description":"\u003cp\u003eThis high performance blade delivers fast and accurate cuts in heavy-duty applications. It has a thin kerf, only 2.16mm, requiring far less power for a given cut. The kerf and 305mm diameter make it perfectly suited for cutting larger, thicker timber. The 7\u003cspecial id=\"8\"\u003e\u003c\/special\u003e hook angle adds to the smooth cutting action. With 78 tungsten teeth and an FZ\/WZ grind (alternate bevel with a flat-topped tooth between each pair), this blade is a good choice for crosscutting, leaving a fine, clean finish on end grain. It has expansion slots for low vibration and reduced noise. The 30mm bore allows the blade to be used on a wide range of machines. Its Extreme Runtime design provides the blade with twice the working life span of more standard blades.\u003c\/p\u003e","brand":"DeWalt","offers":[{"title":"Default Title","offer_id":54118289670491,"sku":"104224","price":87.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104224_xl.jpg?v=1789773868","url":"https:\/\/www.axminstertools.com\/products\/dewalt-extreme-runtime-saw-blade-305mm-x-2-16mm-x-30mm-78t","provider":"Axminster Tools","version":"1.0","type":"link"}
