DeWalt
DeWALT Extreme Runtime Saw Blade - 305mm x 2.16mm x 30mm 78T
SKU: 104224
£87.98
£73.32 Excl. VAT
  • 78 tooth blade for smooth crosscutting
  • Thin kerf; requires less power and effort
  • High quality tungsten teeth for long life
  • Teeth ground for fine clean finish
  • 30mm bore for use on a wide range of machines
  • Anti-vibration and noise damping, expansion slots
This high performance blade delivers fast and accurate cuts in heavy-duty applications. It has a thin kerf, only 2.16mm, requiring far less power for a given cut. The kerf and 305mm diameter make it perfectly suited for cutting larger, thicker timber. The 7 hook angle adds to the smooth cutting action. With 78 tungsten teeth and an FZ/WZ grind (alternate bevel with a flat-topped tooth between each pair), this blade is a good choice for crosscutting, leaving a fine, clean finish on end grain. It has expansion slots for low vibration and reduced noise. The 30mm bore allows the blade to be used on a wide range of machines. Its Extreme Runtime design provides the blade with twice the working life span of more standard blades.
Blade Diameter 305 mm
Maximum RPM 4,800 rpm
Additional Accessories No
Kerf 2.16 mm
Teeth 78
Tooth Format ATBR
Plate Thickness 1.6 mm
Hook Angle 7
Bore Size 30 mm
Web Attribute Set Circular Saw Blades
EAN Barcode 5035048542385
