Extend the reach and reliability of your impact driver with the DeWALT 50mm Impact Torsion Bit and Magnetic Screwlock Sleeve Set, designed for demanding fastening tasks where control and durability matter. Built for high-torque applications, these longer bits provide better access in deeper or awkward fixings while maintaining a secure and consistent drive.
Each bit features a 15° torsion zone that allows it to flex under load rather than break, helping to extend working life in tough conditions. The Full Fit head design improves contact with the screw, reducing cam-out and preventing damage to the fixing. The included Magnetic Screwlock sleeve holds screws securely in place, making one-handed operation easier and reducing the risk of dropped or misplaced screws, ideal for repetitive or overhead work.
DeWALT is known for producing tough, high-performance accessories built to perform reliably in professional environments.
Compatible with DEWALT impact drivers and drills for efficient, controlled fastening across a wide range of materials. Supplied as 2 x PZ2 50mm impact bits and 1 x Magnetic Screwlock Sleeve.
