Silicon Carbide grain coated onto two sides of a low density foam to enable a premium finish on profiled or flat surfaces. Used wet or dry, they are excellent for preparation of surfaces prior to recoating. Available in 60, 100,180 and 220grits. Size approx 98 x 120 x 13mm.
Abrasive Material Silicon Carbide
Abrasive Backing Foam
Abrasive Grit 100
Web Attribute Set Sanding Pads & Sponges
EAN Barcode 4038595755186
