{"product_id":"easy-wood-tools-1-4-negative-rake-beading-cutter","title":"Easy Wood Tools 1\/4\" Negative Rake Beading Cutter","description":"\u003cp\u003eTop tips for turning tools. This negative rake carbide tip will produce a perfect 6.35mm (1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter semi-circular bead on any of your turning projects. The tip is made to fit the following Easy Wood Tools: Easy Start Easy Rougher, Mini Easy Rougher and Mid-Size Easy Rougher, which all take Ci2 size Easy Wood tips.\u003c\/p\u003e\u003cp\u003eThe negative rake on this profiling tip produces a smoother finish as the cutting action is less aggressive. It is effective on timber, as well as resins, acrylic, and other man-made materials. Producing a perfect bead could not be easier. It ensures that repeated beads are even and equal. Turn your Easy Rougher into a multi-use tool.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools is the only turning company that manufactures its own carbide. All the tips are made in the Easy Tools manufacturing plant in Illinois USA. Easy Tools has complete control over the process and the quality. Their proprietary formula is the sharpest, hardest and longest-lasting in the industry.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118487818587,"sku":"109647","price":35.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109647_xl.jpg?v=1789782226","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-1-4-negative-rake-beading-cutter","provider":"Axminster Tools","version":"1.0","type":"link"}
