Top tips for turning tools. This negative rake carbide tip will produce a perfect 6.35mm (1/4) diameter semi-circular bead on any of your turning projects. The tip is made to fit the following Easy Wood Tools: Easy Start Easy Rougher, Mini Easy Rougher and Mid-Size Easy Rougher, which all take Ci2 size Easy Wood tips.
The negative rake on this profiling tip produces a smoother finish as the cutting action is less aggressive. It is effective on timber, as well as resins, acrylic, and other man-made materials. Producing a perfect bead could not be easier. It ensures that repeated beads are even and equal. Turn your Easy Rougher into a multi-use tool.
