These Easy Wood Easy Stepped Dovetail Jaws are designed to offer a secure and dependable grip on your workpiece. They incorporate concentric rings for a wide range of tenon size mounting.
Swapping your jaws is easy; use the ball and hex key, press down on the keeper latch, slide your jaws on, listen to the snap and the jaw is then locked into position within 30 seconds.
The jaws grip tenons at 2.1/2, 3 and 3.1/2 and expand in mortices at 4.1/4+. The jaw length is 1.
Compatible with the Easy Chuck only.
Web Attribute Set Jaws for Four Jaw Chucks
