{"product_id":"easy-wood-tools-big-easy-jaws","title":"Easy Wood Tools Big Easy Jaws","description":"\u003cp\u003eThese Big Easy Jaws\u003cspecial id=\"10\"\u003e\u003c\/special\u003e are perfect for the inside of bowls, platter and hollow forms. They include 8 urethane Easy Grippers\u003cspecial id=\"10\"\u003e\u003c\/special\u003e that help to protect your work, ideal for when your finish has already been applied and you are working on the base of your piece.\u003c\/p\u003e\u003cp\u003eSwapping your jaws is easy, thanks to Snap-Lock Technology; use the ball and hex key, press down on the keeper latch, slide your jaws on, listen to the snap and the jaw is then locked into position within 30 seconds.\u003c\/p\u003e\u003cp\u003eThe 12\u003cspecial id=\"1\"\u003e\u003c\/special\u003e Big Easy Jaws have a maximum grip diameter of 10\u003cspecial id=\"32\"\u003e\u003c\/special\u003e and the maximum expanding dimension is 11.1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e. When jaws are fully closed, the outer diameter is 10.3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e. Fully open, the outer diameter is 12\u003cspecial id=\"32\"\u003e\u003c\/special\u003e. Please ensure your lathe has a minimum swing of 12\u003cspecial id=\"1\"\u003e\u003c\/special\u003e when using these jaws.\u003c\/p\u003e\u003cp\u003eThe 16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e Big Easy Jaws have maximum grip diameter of 14\u003cspecial id=\"1\"\u003e\u003c\/special\u003e and the maximum expanding dimension in 15.1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e. When jaws are fully closed, the outer diameter is 14.3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e. Fully open, the outer diameter is 16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e. Please ensure your lathe has a minimum swing of 16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e when using these jaws.\u003c\/p\u003e\u003cp\u003eBoth supplied with 4 base jaws, 4 jaw plates, 8 dovetail grippers and 1 5\/32\u003cspecial id=\"32\"\u003e\u003c\/special\u003e T-handle hex wrench.\u003c\/p\u003e\u003cp\u003eCompatible with the Easy Chuck only.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"12","offer_id":54162823512411,"sku":"113277","price":300.0,"currency_code":"EUR","in_stock":true},{"title":"16","offer_id":54162823545179,"sku":"113278","price":325.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113277_xl.jpg?v=1790102639","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-big-easy-jaws","provider":"Axminster Tools","version":"1.0","type":"link"}
