{"product_id":"easy-wood-tools-ci1-r2-nr-carbide-cutter-2-negative-rake","title":"Easy Wood Tools Ci1-R2-NR Carbide Cutter 2\" Negative Rake","description":"\u003cp\u003eThe Ci1-R2-NR negative rake carbide tip is 14.6mm square. It fits the Full-Size Easy Rougher and Pro Easy Rougher.\u003c\/p\u003e\u003cp\u003eNegative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.\u003c\/p\u003e\u003cp\u003eEach of the four edges is slightly curved with a radius of 2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e, hence the R2 suffix. The radius along the edge, minimises the risk of a catch from a sharp corner when moving the chisel from side-to-side.\u003c\/p\u003e\u003cp\u003eWhen one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools is the only turning company that manufactures its own carbide. All the tips are made in the Easy Tools manufacturing plant in Illinois USA. Easy Tools has complete control over the process and the quality. Their proprietary formula is the sharpest, hardest and longest-lasting in the industry.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118469796187,"sku":"109251","price":23.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109251_xl.jpg?v=1789781516","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-ci1-r2-nr-carbide-cutter-2-negative-rake","provider":"Axminster Tools","version":"1.0","type":"link"}
