Easy Wood Tools
Easy Wood Tools Ci2-SQ Carbide Cutter Square
SKU: 109254
£15.88
£13.23 Excl. VAT
  • Fits the Easy Start, Mini Easy and Mid-Size Easy Roughers
  • 10.8mm square, solid carbide
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible.
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci2 solid carbide tip is 10.8mm square. It fits the Easy Start Rougher, Mini Easy Rougher and Mid-Size Easy Rougher.
​The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
