Easy Wood Tools
Easy Wood Tools Ci3-NR Carbide Cutter - Round Negative Rake
SKU: 109313
£20.88
£17.40 Excl. VAT
  • Fits: Easy Start Easy, Mini Easy and Mid-Size Easy Finishers
  • Fits: Full-Size Easy Hollower #3 and all Pro Easy Hollowers
  • 11.3mm diameter, solid carbide
  • Negative rake for acrylics, resin and very hard woods
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci3-NR solid carbide negative rake cutter is 11.3mm diameter. It fits the Easy Start Easy Finisher, Mini Easy Finisher, Mid-Size Easy Finisher, Full-Size Easy Hollower #3, Pro Easy Hollower #1, Pro Easy Hollower #2, and Pro Easy Hollower #3.
Negative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.
When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
