{"product_id":"easy-wood-tools-ci4-carbide-cutter-diamond","title":"Easy Wood Tools Ci4 Carbide Cutter - Diamond","description":"\u003cp\u003eThe Ci4 solid carbide diamond shaped tip is 9.6mm wide. It fits the Easy Start Easy Detailer, Mini Easy Detailer, and Mid-Size Easy Detailer, Full Size Easy Detailer and Pro Easy Detailer.\u003c\/p\u003e\u003cp\u003e​The standard carbide cutters provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.\u003c\/p\u003e\u003cp\u003e​When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools is the only turning company that manufactures its own carbide. All the tips are made in the Easy Tools manufacturing plant in Illinois USA. Easy Tools has complete control over the process and the quality. Their proprietary formula is the sharpest, hardest and longest-lasting in the industry.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118472647003,"sku":"109262","price":22.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109262_xl.jpg?v=1789781569","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-ci4-carbide-cutter-diamond","provider":"Axminster Tools","version":"1.0","type":"link"}
