{"product_id":"easy-wood-tools-ci6-r1-carbide-cutter-1-radius","title":"Easy Wood Tools Ci6-R1 Carbide Cutter 1\" Radius","description":"\u003cp\u003eThe Ci6-R1 solid carbide tip is 9.6mm square. It fits the Micro Easy Rougher.\u003c\/p\u003e\u003cp\u003eEach of the four edges is slightly curved with a radius of 1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e, hence the R1 suffix. The radius along the edge, minimises the risk of a catch from a sharp corner when moving the chisel from side-to-side.\u003c\/p\u003e\u003cp\u003e​The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.\u003c\/p\u003e\u003cp\u003e​When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools is the only turning company that manufactures its own carbide. All the tips are made in the Easy Tools manufacturing plant in Illinois USA. Easy Tools has complete control over the process and the quality. Their proprietary formula is the sharpest, hardest and longest-lasting in the industry.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118474678619,"sku":"109212","price":19.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109212_xl.jpg?v=1789781607","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-ci6-r1-carbide-cutter-1-radius","provider":"Axminster Tools","version":"1.0","type":"link"}
