{"product_id":"easy-wood-tools-ci7-nr-carbide-cutter-diamond-negative-rake","title":"Easy Wood Tools Ci7-NR Carbide Cutter - Diamond Negative Rake","description":"\u003cp\u003eThe Ci7-NR solid carbide, negative rake tip is diamond shaped, 8.3mm wide. It fits the Micro Easy Detailer and Mid-Size Micro Easy Detailer.\u003c\/p\u003e\u003cp\u003eNegative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.\u003c\/p\u003e\u003cp\u003eWhen one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools is the only turning company that manufactures its own carbide. All the tips are made in the Easy Tools manufacturing plant in Illinois USA. Easy Tools has complete control over the process and the quality. Their proprietary formula is the sharpest, hardest and longest-lasting in the industry.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118475170139,"sku":"109301","price":30.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109301_xl.jpg?v=1789781632","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-ci7-nr-carbide-cutter-diamond-negative-rake","provider":"Axminster Tools","version":"1.0","type":"link"}
