These Easy Wood Easy Dovetail Jaws are designed to offer a secure and dependable grip on your workpiece. They are versatile to hold a range of different projects.
Swapping your jaws is easy; use the ball and hex key, press down on the keeper latch, slide your jaws on, listen to the snap and the jaw is then locked into position within 30 seconds.
The 1.3/8 Easy Dovetail Jaws are the standard jaws that come with the Easy Chuck. They grip tenons at 1.3/8+ and expand in mortices at 2. The jaw length is 7/16.
The 2.3/8 Easy Dovetail Jaws grip tenons at 2.3/8+ and expand in mortices at 3 +. The jaw length is 7/16.
Compatible with the Easy Chuck only.
Manufactured with hardened and plated components and machined to high tolerances.
Web Attribute Set Jaws for Four Jaw Chucks
