{"product_id":"easy-wood-tools-easy-micro-tools-3-piece-set","title":"Easy Wood Tools Easy Micro Tools™ 3-Piece Set","description":"\u003cp\u003eThe Easy Wood Tools Easy Micro Tools™ 3‑Piece Set brings together the essential tools needed for small‑scale woodturning, including roughing, shaping, and fine detailing.\u003c\/p\u003e\u003cp\u003eThe set includes a Micro Easy Rougher™, Micro Easy Finisher™, and Micro Easy Detailer™, making it ideal for working on pens, bottle stoppers, ornaments, and other miniature turning projects.\u003c\/p\u003e\u003cp\u003eEach tool in the set features a replaceable carbide cutter and a flat‑profile bar that sits securely on the tool rest, making them easy to control and intuitive to use.\u003c\/p\u003e\u003cp\u003eWith no sharpening required, the Micro set is particularly suited to beginners or anyone looking for a simple, low‑maintenance system for small‑scale turning. The compact size of each tool allows for excellent control in tight or detailed work.\u003c\/p\u003e\u003cp\u003eTogether, the three tools provide a complete system for small turning projects. The Rougher™ efficiently removes material to establish shape, the Finisher™ refines curves and smooths surfaces, and the Detailer™ adds fine definition and decorative detail.\u003c\/p\u003e\u003cp\u003eUsed parallel to the floor at centre height, each tool remains stable on the rest, helping reduce catches and allowing for clean, controlled cuts. The combination of compact tool size and carbide cutters delivers predictable results, even on delicate or small‑diameter workpieces.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eSet includes: Micro Easy Rougher™, Micro Easy Finisher™, Micro Easy Detailer™\u003c\/p\u003e\u003cp\u003eCutter types: Square, round, and diamond carbide cutters\u003c\/p\u003e\u003cp\u003eRange: Micro (compact tools for small‑scale turning)\u003c\/p\u003e\u003cp\u003eBar profile: Flat section for stability on the tool rest\u003c\/p\u003e\u003cp\u003eHandles: Hardwood with copper ferrules\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to produce a smoother finish and improved control on delicate materials.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118475858267,"sku":"109207","price":250.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109207_xl.jpg?v=1789781655","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-easy-micro-tools-3-piece-set","provider":"Axminster Tools","version":"1.0","type":"link"}
