Easy Wood Tools
Easy Wood Tools Easy Parting Tool™ 3.2mm
SKU: 109324
£157.88
£131.57 Excl. VAT
  • Make parting cuts with confidence and control
  • Designed for safe and stable parting-off
  • 3.2mm wide negative rake carbide tip
  • Solid carbide tip keeps an edge many, many times longer than HSS
  • Up to 63.5mm depth of cut
  • American Maple handle with copper ferrule for strength
The Easy Wood Tools Parting Tool cuts very cleanly, whilst providing precise and stable control. It makes parting your work safer and steadier. In line with all the Easy Wood Tools’ range, it features a carbide cutting tip. This 3.2mm wide negative rake tip is permanently brazed onto a stainless steel blade for security. If the time ever comes when you need a new tip, you simply replace this assembly.
The geometry of the tip allows for side cutting and undercutting techniques. The unique design with its negative rake allows you to part-off up to 125mm diameter with great control.
The Easy Wood Tools Parting tool is fitted with a 355mm long straight grained American Maple handle with a copper ferrule for strength.
The overall length is 483mm.
The shaft is engraved with the corresponding replacement cutter reference number.
Replacement Tip Pi160 (109323)
