{"product_id":"easy-wood-tools-easy-start-easy-finisher","title":"Easy Wood Tools Easy Start EASY FINISHER™","description":"\u003cp\u003eThe Easy Wood Tools Easy Start Finisher is a carbide woodturning tool designed for making coves, hollows, sweeping curves, and final shaping. Ideal for pens, wine bottle stoppers, spindles, and small bowls or shaped projects, it supports beginners as they refine form while offering experienced turners a smooth, low‑maintenance finishing option.\u003c\/p\u003e\u003cp\u003eFeaturing a replaceable round carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Easy Start Finisher delivers excellent stability and easy control with no sharpening required.\u003c\/p\u003e\u003cp\u003eEconomical and intuitive, it is particularly well suited to beginners, education settings, and training environments, while remaining a practical alternative for experienced turners looking for a controlled, predictable finishing tool.\u003c\/p\u003e\u003cp\u003eDesigned to produce smooth, flowing cuts, the Easy Start Finisher is ideal for forming curves, refining hollows, and achieving clean final shapes.\u003c\/p\u003e\u003cp\u003eThe square section bar ensures the tool remains flat and steady on the tool rest, and when used parallel to the floor at centre height, the risk of catches and snatches is virtually eliminated, helping turners work confidently during finishing cuts.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eRound carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003eHex key for easy cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e230mm American maple handle with copper ferrule for added strength\u003c\/p\u003e\u003cp\u003eColour‑coded handle for easy identification within the Easy Start range\u003c\/p\u003e\u003cp\u003eWith no sharpening needed, maintenance is simple - when the edge becomes dull, just loosen the fixing screw and rotate the cutter to a fresh edge.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters keep an edge many times longer than HSS and are suitable for turning dry or green wood, as well as acrylics.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 318mm\u003c\/p\u003e\u003cp\u003eBar profile: 9.5mm square section\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin materials, while also producing a finer, smoother finish on timber as skills develop.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118468157787,"sku":"109320","price":69.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109320_xl.jpg?v=1789781394","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-easy-start-easy-finisher","provider":"Axminster Tools","version":"1.0","type":"link"}
