{"product_id":"easy-wood-tools-full-size-easy-detailer","title":"Easy Wood Tools Full-Size EASY DETAILER™","description":"\u003cp\u003eThe Easy Wood Tools Full‑Size Easy Detailer™ is a carbide woodturning tool designed for creating fine details, small coves, crisp beads, and tight-radius features on large bowls, table legs, spindles, platters, and substantial turning projects. As part of the Full‑Size range, it offers increased leverage and reach, making it ideal for precision work on bigger pieces where stability and control are essential.\u003c\/p\u003e\u003cp\u003eFeaturing a diamond‑shaped replaceable carbide cutter and a 12.7mm square section bar, the Full‑Size Easy Detailer™ sits flat on the tool rest, delivering excellent stability and easy, predictable control with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe extended 406mm American Maple handle provides generous leverage, making delicate detailing on large or deep forms feel smoother and more controlled, even when visual access is limited.\u003c\/p\u003e\u003cp\u003eThe Full‑Size Easy Detailer™ excels at clean, precise detail work, allowing you to produce sharp transitions, accent lines, beads, and decorative features on larger projects.\u003c\/p\u003e\u003cp\u003eWith the tool held parallel to the floor at centre height, the square bar keeps the tool steady and helps virtually eliminate catches and snatches, making intricate detail work safer and more confidence‑building—especially on broader or heavy-duty blanks.\u003c\/p\u003e\u003cp\u003eWith no sharpening needed, simply loosen the fixing screw and rotate the cutter to expose a fresh, sharp edge when it eventually dulls.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ premium solid carbide lasts many times longer than HSS and is suitable for turning dry or green wood, acrylics, and resin.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eDiamond‑shaped carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003eHex key for easy cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e406mm American Maple handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003e12.7mm square section bar for maximum stability\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick identification within the range\u003c\/p\u003e\u003cp\u003eShaft engraved with carbide cutter reference number\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 622mm\u003c\/p\u003e\u003cp\u003eHandle length: 406mm\u003c\/p\u003e\u003cp\u003eBar profile: 12.7mm square\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin materials, producing a finer, smoother finish on timber during detailed shaping.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136154882395,"sku":"109264","price":150.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109264_xl.jpg?v=1790004660","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-full-size-easy-detailer","provider":"Axminster Tools","version":"1.0","type":"link"}
