The Easy Wood Tools Full‑Size Easy Detailer™ is a carbide woodturning tool designed for creating fine details, small coves, crisp beads, and tight-radius features on large bowls, table legs, spindles, platters, and substantial turning projects. As part of the Full‑Size range, it offers increased leverage and reach, making it ideal for precision work on bigger pieces where stability and control are essential.
Featuring a diamond‑shaped replaceable carbide cutter and a 12.7mm square section bar, the Full‑Size Easy Detailer™ sits flat on the tool rest, delivering excellent stability and easy, predictable control with no sharpening required.
The extended 406mm American Maple handle provides generous leverage, making delicate detailing on large or deep forms feel smoother and more controlled, even when visual access is limited.
The Full‑Size Easy Detailer™ excels at clean, precise detail work, allowing you to produce sharp transitions, accent lines, beads, and decorative features on larger projects.
With the tool held parallel to the floor at centre height, the square bar keeps the tool steady and helps virtually eliminate catches and snatches, making intricate detail work safer and more confidence‑building—especially on broader or heavy-duty blanks.
With no sharpening needed, simply loosen the fixing screw and rotate the cutter to expose a fresh, sharp edge when it eventually dulls.
Easy Wood Tools’ premium solid carbide lasts many times longer than HSS and is suitable for turning dry or green wood, acrylics, and resin.
What you get
Diamond‑shaped carbide cutter fitted as standard
Hex key for easy cutter rotation or replacement
406mm American Maple handle with copper ferrule for strength
12.7mm square section bar for maximum stability
Colour‑coded handle for quick identification within the range
Shaft engraved with carbide cutter reference number
Specifications
Overall length: 622mm
Handle length: 406mm
Bar profile: 12.7mm square
Optional upgrade
Negative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin materials, producing a finer, smoother finish on timber during detailed shaping.
